I just replaced my slave cyl., and rebuilt my clutch master. I used a 'Pheonix Injector' to bleed my system. This works by pumping fluid at the slave cylinder, and up to the master. I connected a hose to the bleeder line at the inner fender, so it would drip into a container. I pumped fluid until in came out of the bleeder line, and at the same time the resevoir of the master was bled, and filled. tighten both bleeder screws. Clutch works perfect.
